diagonal sweep / circular sweep
Message 1 of 9
Is it possible to make a diagonal /circular sweep instead of just horizontal or vertical?
I found this forum but the link is not working anymore.. :
https://forums.autodesk.com/t5/revit-architecture-forum/diagonal-wall-reveals-and-sweeps/m-p/1938839...
@barthbradley @ToanDN
Replies (8)
Message 2 of 9
Sure you can.  Do you have a specific application in mind?  Post a screenshot or the file so we can see exactly what you are want to path your sweep along.
Message 3 of 9
I wanted to apply it 1 . on a surface with diagonal top, and 2. on a circular floor that popsout of the wall
Message 4 of 9
You should be able to do that with an In-Place Modeled Sweep.  Post the file so I can get a better look at it.
Message 5 of 9
martijn_pater
You can do a sweep in pretty much any direction you want fyi... yours seems pretty straightforward though so an in-place sweep might be enough, as @barthbradley mentioned.
sweep xyz-directionsweep xyz-direction
Message 6 of 9
Not Wall Sweeps. But you can draw it using in-place model sweep and pick 3d edges for the swept path.
Message 7 of 9
Yes I was using wall sweeps indeed, sorry i didnt tell. Can i find  somewhere how i can place an in model sweep as you are mentioning?
Message 8 of 9
Architectural Tab=>Component=>Model In-Place.  All the modeling tools you need are right there. Same workflow as modeling a Loadable Family.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
...tell you what; post your RVT and I'll put an In-Place Modeled Sweep in it and return it to you for your examinination.  Free of charge. 😉
Message 9 of 9
FacebookGroupMember
Source Message URL: https://forums.autodesk.com/t5/revit-architecture-forum/diagonal-sweep-circular-sweep/m-p/9881970M30...
