I have an elevation tag for objects (yellow) but the issue is i need the elevation to show as total inches (example 44").
I do not want to change the (blue) dimensions in a project, so changing the project units would be out.
I do not want a work around where i type (+44") into a comments tag.
I have a feeling there is a solution in the tag itself by creating a formula tag to convert that Ft' Inches" into Inches"
Any ideas?
Gelöst! Gehe zur Lösung
I figured it out. There is an option at the bottom of the tag to not use project units.
