Detailed based line with nested item.
Darwin33
Darwin33
I am creating a detailed line based family with a item nested on it. The problem is that I am not able to set up the correct distance between the items, i.e. de separation distance between the array items.
Any tutorial to view and check that can be recomended.
RDAOU
@Darwin33
You need to set ref planes to constrain first and second instances of the array:
  1. dimensions/lock  the distance
  2. then align and lock the first and second instances of the array to the ref planes
  3. and make sure the array is set to append to end
Once you tend to the previous post I will consider recording a tutorial
EDIT: On the same topic and line based family and arrayed detail item, has this been sorted out first? There has been a suggestion there addressing the issue of the array (use the simpler method by using repeating details instead of arrays)
https://forums.autodesk.com/t5/revit-architecture-forum/family-detail-items-line-based/m-p/10967583
Darwin33
Thank you for your help, I rather the method of the detailed based line, because I can make it parametric to include several insulations profiles.
RDAOU
@Darwin33
Your call... However, a repeating detail is an array similar to a line based family array. you can have in it as much profiles as necessary!!
Anyhow, I will not be able to help you with the tutorial if previous reply is not solved. One fix at a time 🙂
