Detail Libraries
Detail Libraries
Message 1 of 12
Detail Libraries
Hello All.
I'm using the trial version of Revit Architecture 2021. Trying to add 2d details and although I see the library it won't allow me to load saying " Some of the family files you selected cannot be loaded. You must choose family files of the category Component. Do you want to retry loading a new set of files?" Anything I choose gets the same message. Any solutions?
Replies (11)
Message 2 of 12
syman2000
You may want to download and install the content from the link below. I've also have the same issue when my content is missing when installing 2021
https://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/autodesk-revi...
Message 3 of 12
Thank you Syman2000 for your reply. I already went there. 1st you have to run the .exe file as administrator or else it doesn't load all files. Next, I still get an error message. The work around is to open the library from File>Open>Family and then once open to click Load into project.
Message 4 of 12
What are you doing specifically? Sounds like you are selecting the Detail Component while inside an editing session and that session is looking for a specific Family Component. Revit is telling you that the Family you selected is not what it's looking for.  BTW: there is no "Component" Category.  Read the Error Message again.   It should include a Family Category Name.
Message 5 of 12
Example. I activated Window command and then hit "Load Family" and tried to load an "Annotation" Family:
Message 6 of 12
_Vijay
From insert load family..
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 7 of 12
That's exactly what I've done and got the same pop-up. I was trying to load a brick tie detail.
Message 8 of 12
Why not make it easier on yourself by pre-loading the Detail into your Project?
Message 9 of 12
Mohamed-Nassar
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
This link will help you check it
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Message 10 of 12
Mohamed-Nassar
there is some thing like u talked about
Message 11 of 12
ennujozlagam
i have a feeling that is a 2d drawing or .DWG extention? if yes then you can select link cad or import CAD and see if helps. thanks
Message 12 of 12
Thank you very much!
