Gelöst! Gehe zur Lösung
Gelöst von anita.leja. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Stair sketchmode won't allow you to cross boundary with another. You may want to create a stair away from the conflict area.
You can cross over another flight of stair using Component Stairs. Are Component Stairs available to you? I think they were introduced in 2018. If not, separate the flights into two different sketches.
Thank you. I thought that that could be the problem. I stretched the middle run so others two won't cross. That solved the problem.
