Scope boxes are disappearing
Annotation symbols are changing sizes
View ports are moving around on sheets
but the weirdest thing is this:
I grab the viewport title and the viewport rotates AROUND the title
Solved by JordanBillingsley. Go to Solution.
This is strange behavior. Is it possible to strip the model down a bit and then attach it? I could also set up a upload location if that is easier for you.
I would like to take a look at this issue for you.
Hi jbillingsley465,
I haven't seen an update on your post and hope that means you resolved your issue. If not, please update as I am happy to assist you with this issue.
Please also tell me, is this happening in all of your models or just the one? A specific view or all views?
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
Thank you for the support and replies, I apologize for my absence. The issue was "resolved" by recreating the dependent views - which was not very difficult for this project. I do not have a explanation as to what may have cause this but will report if the issue creeps back.
Thank you!
