Dependent View - Weird things are happening
3 REPLIES 3
JordanBillingsley
279 Views, 3 Replies
Scope boxes are disappearing
Annotation symbols are changing sizes
View ports are moving around on sheets
but the weirdest thing is this:
I grab the viewport title and the viewport rotates AROUND the title
3 REPLIES 3
Hi @JordanBillingsley,
This is strange behavior. Is it possible to strip the model down a bit and then attach it? I could also set up a upload location if that is easier for you.
I would like to take a look at this issue for you.
John Vellek
Hi jbillingsley465,
I haven't seen an update on your post and hope that means you resolved your issue. If not, please update as I am happy to assist you with this issue.
Please also tell me, is this happening in all of your models or just the one? A specific view or all views?
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Thank you for the support and replies, I apologize for my absence. The issue was "resolved" by recreating the dependent views - which was not very difficult for this project. I do not have a explanation as to what may have cause this but will report if the issue creeps back.
Thank you!
Forma Design Contest
