Deleting visibility graphic parameter
A_MAQ
Advisor Advisor
A_MAQ
Hello all,
i created  a visibility graphic parameter and i want to delete it , how can i delete it ?
Autodesk Expert Elite
L.Maas
Within the family. Close the shown box. Go to "Family Types". Ther you will find the list with all the parameters.
Select the parameter you wish to delete and clik "Remove".
Revit might throw up a box that the parameter is in use, but you still can delete it.
Louis
Please mention Revit version, especially when uploading Revit files.
A_MAQ
OH THANKS , I DO NOT HOW I FORGET THAT
THANKS A LOT
RDAOU
  1. Select the family in your model and on the ribbon > Edit Family
  2. Under Ribbon Properties section > Family Type
  3. Select and delete the Yes/No parameters for visibility
If those parameters are functioning why delete them? Personally I find them quite useful in site and topo layouts...You have the option to keep those parameter and just unassign them. If you know or can locate which element of the family they control (example the frame of the door, the sill or header of a window...) in your case those 01, 02, 03 ... elements...
  1. select that element which is controled by those parameters
  2. Go to the properties dialog >> visibility >>
  3. Cclick the [...] box at the right end of the visibility field next to the checkbox.
  4. select <none>
  5. Ok Ok to return to family
  6. save and lod back to your project
