creating stud walls in revit 2016
i am very new to this program
ihave searched and experimented but i cannot create a veiw of a stud framed wall
i see there are extensions for this in older versions
do i need to use 2015 for example instead of 2016
RDAOU
You either get an Add-in (There is a nice one from ClarkDietrich BIM and StrucSOFT)
OR
You can model it yourself using Curtain Wallwith two liners (basic walls consisting of gypsum liner)
To add openings/inserts (doors and windows) you have to join geometry and insert a Wall Opening (Architectural>Opening>Wall Opening) identical to the door/window opening
I can create a screencast of the Revit custom modeled one if you need help with it
Thank you
Yes I have tried this method also but there is a track showing in the wall that would receive a window. Also I have not been able to change the shape of the wall to be pitched on the top
Sent from Mail for Windows 10
RDAOU
ScreenCast maybe this helps
Thank you for the demonstration. This will help me to get the final result i was looking for.
