DELETING imported dwg
yoiyoi
yoiyoi
i'd like to delete imported dwg file . i selected it and deleted in the view screen and went to the visibility graphic and selected the file from under imported category tab but there is no button for delete
If you already deleted it from the view then that's it, there is nothing to delete from Imported categories.
Kobanion
Observer
Observer
THE DRAWING FILES THAT ARE IMPORTED STILL SHOW UP IN THE IMPORTED TAB IN THE TEMPLATES EVEN THOUGH ONE DELETES THEM IN THE MODEL. WHY DO THEY NOT DISSAPEAR IN THE TEMPLATE IMPORT TAB? IT CLOGS UP THE LIST AND MAKES IT IMPOSSIBLE TO NAVIGATE AND TOGGLE WHAT NEEDS TO BE TOGGLED. REVIT SHOULD COMBINE THE LINK AND IMPORT COMMAND TO WORK MORE SEAMLESSLY.
RobDraw
People should ask how to do things before making such demands.
Rob
