when i change my view from 3d view where the model is visible to any of the plans the model is no more visible and too small to locate . is there an equivalent for zoom extents in revit?
The elements are too far away from the Internal Origin of the Project. Turn on the Internal Origin in the 3D View, Zoom Extent plus a little more, do a crossing-window selection of the entire view. This should pick up everything. Press the Filter button on the Contextual Tab to see what they are. Those elements that are way far away from the Internal Origin need to be moved closer to the IO. You can use Filter to select only those elements and then press Move to move those elements closer to the IO. It might take several Moves to get those elements to the right location. Just depends on how far away they are.
thanks for responses when i do ZE i see the bounding box of imported dwg way bigger than the model but when i do zoom extents in autocad the imported dwg fills the screen and i made sure it was near origin 0,0,0 .also using the filter button it is the only imported dwg in the model. what am i doing wrong?
Check for OFf and frozen layers in AutoCAD see if any elements in those layers are far off origin.
