Decal does not show
15 REPLIES 15
Message 1 of 16
emmanuelbee
9584 Views, 15 Replies
Decal does not show
emmanuelbee
I'm trying to place a decal of an image on a wall in my elevation view and for some reason when i place the decal on the wall, it only shows the outline frame of the decal which lets me know that the image has been placed, but the actual image is not visible and i don't know why, i've tried it with different images and the same thing happens sometimes it does show if i change the graphical settings to realistic but most of the time its not visible. I've attached an image of what i'm talking about.
Decal does not show
15 REPLIES 15
Message 2 of 16
in reply to: emmanuelbee
Decals only show under Realistic, Raytracing, and Rendering
Message 3 of 16
emmanuelbee
in reply to: ToanDN
emmanuelbee
ok i didn't know that decals only shows under those views, but still the image that I'm using doesnt show even in realistic view
Message 4 of 16
Doesn't sound like you created/defined the decal type properly.
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-84E954A2-D483-4E41-8DD0-41C23C164D4A
Message 5 of 16
aRcHiTeCt.JM
aRcHiTeCt.JM
you have to check that you are creating and uploading the image you want to show
if you follow instructions you will get perfect results
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 6 of 16
cbcarch
cbcarch
Check to see exactly which surface the decal is attached to--you may need to set the current workplane to the surface that the decal needs to be hosted to BEFORE placing the decal onto the model element.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Cliff B. Collins
Message 7 of 16
emmanuelbee
in reply to: cbcarch
emmanuelbee
I was using Revit 2018 and it wasn't working, I've just downloaded and tried it in Revit 2019, its now working fine. Maybe decals don't work properly in revit 2018?
Message 8 of 16
cbcarch
cbcarch
Glad you got it working.
From my experience, Decals have worked properly in all versions of Revit since they were implemented.
I don't think switching from 2018 to 2019 was the difference--it was something about the method used.
Can you describe exactly how you got it to work in 2019?
Cliff B. Collins
Cliff B. Collins
Message 9 of 16
emmanuelbee
emmanuelbee
I created a new decal type, browsed my local disk to select the image that i wanted to use and then placed it on the face of a wall and then chose realistic view and it worked, its weird because that's exactly what i was doing in revit 2018 and it was acting funny, I don't know if i accidentally clicked on something in the settings which made it not work but i'm pretty sure I followed the same steps
Message 10 of 16
I can clearly see the decal frame in your screenshot; there's just no image associated with it. Have you inspected that decal type properties to see what image is assigned, if any?
Message 11 of 16
emmanuelbee
in reply to: barthbradley
emmanuelbee
I've got it working now thanks
Message 12 of 16
Viveka_CD
Viveka_CD
Autodesk Support
Autodesk Support
Hi @emmanuelbee
Is you Revit 2018 updated to the latest build?
What is the format of the image you are using?
Hi @emmanuelbee
Message 13 of 16
emmanuelbee
in reply to: Viveka_CD
emmanuelbee
I've managed to get it working now thanks
Message 14 of 16
in reply to: ToanDN
Also check your wall properties, as I has an issue where it wouldnt render ontop of a block wall but over gypsum board it would. So i had to change my wall properties to allow a decal to be placed and rendered.
Message 15 of 16
kfinnN7KSP
kfinnN7KSP
Should the decal be visible in 3d viewer? I need to see it in 3d but only see the decal in elevation.
Message 16 of 16
tadiwarazuwika
Community Visitor
Community Visitor
Decal works for me when your visual style is realistic. If its shaded, hidden and wireframe, you won't be able to see the image. still trying to figure out how to make it work other visual styles. Hope someone will assist
