Hi there,
My furniture/pluming families seen in grey are overriding/in front of the black lines of the walls in my plans. Is there an easy way for the black lines of the walls to take graphic priority over the grey furniture? I want the walls to show as continuous.
Thanks for your help.
Still looking for some assistance on this. Any help is appreciated. Thanks.
Does the grey override the black lines of the walls when you print?
If you start a new project, model a wall and then place your plumbing families does it do the same thing?
Change the furniture/pluming families Line Weight to 1 in your object styles:
If this doesn't update the style as expected, check the overrides hierarchy:
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-67D3D6DB-E78D-4711-B9C3-4D30F1C22205
Please, like this post and accept as solution!
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
