Data in file an unnamed is corrupt and needs to be manually recovered
i have tried everything to open the file but it is not opening
KrisAribal
is this file has an active worksets enable? have you tried auditing it?
KrisAribal
There's a repair central model tool that's available. You just have to select a local file. It's a hidden option right under the manage models.
nmarcelis
Assuming you dont have an automatic backup of the file laying around. You can manually recover a backup in the journal folder on your pc.
Check the provided link for more information.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
If this helped pleased click on accept solution.
Revit Certified Professional Architecture, Structure and MEP.
