Export Revit 3D to .FBX Fatal Error
When attempting to export Revit 3D view to .fbx (destination 3Ds Max), we receive "An unrecoverable error has occurred. The program will now be terminated". Revit 2018 is up to date. File is a site plan with several linked models. Any ideas? Many thanks and regards.
ennujozlagam
hello, try to save to another filename, bind all your linked files , remove all your linked cad files, audit and purged. clean as much as possible. delete all those objects you don't want. and now try to export to FBX and see if helps. thanks
