07:25 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is there any way I can prevent this from happening. The wall highlighted with the red lines joins up through the steel column. I only want the plasterboard element of the wall type to join. The only thing I can see is Notch but that's for the beams and columns not walls.
Also, when I perform a wall opening say in a metalstud wall with plasterboard finish, how come when the opening has been created the plasterboard does not turn the corner into the opening just like what would be done on site in real life. I've tried altering the wrapping at inserts or ends but that doesn't seem to make a difference.
