Elevation visibility issues
30 ANTWORTEN 30
GELÖST
Nachricht 1 von 31
Sahay_R
2165 Aufrufe, 30 Antworten
Hello all,
Issue here. Prepare yourselves for some drama.....
Two elevation views.
Only difference is the scale.
One elevation is of the full building,
The other is an enlarged detail of a part of the same building.
Both are of Type - Building Elevation
Both have the same view template.
Same project
Same files linked in  - a .dwg, an MEP
Both linked files are in the correct workset
When I  go to the view template to hide the .dwg, exterior lights on the detail view disappear. These lights are a part of the MEP file.
The overall elevation looks fine however!!
This has been driving me absolutely nuts. What could the difference be between the overall elevation and the enlarged elevation that could be causing this? A part of me is strongly tempted to recommend linework on the offending detail, but that would not be right - and I would not be able to sleep at night!
Oh Revit, Revit, wherefore art thou, Revit.....
Smiley (traurig)
Rina
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
30 ANTWORTEN 30
Nachricht 2 von 31
als Antwort auf: Sahay_R
It would help to go step by step from the correct view towards the other to see where things break.
I would duplicate the correct one, crop it, change the scale and see where the lights disappear.
Nachricht 3 von 31
So, if I understands correctly, you're going to: "View Template">"V/G Imports" and then unchecking the checkbox next to your ".dwg" file name, and leaving the checkbox next to "Show imported categories in this view" checked. Is that right? If so, a filter might be the culprit.
...Do you get the same results if you select the dwg and do a "Temporary Hide"?
Nachricht 4 von 31
Can you share your View Template properties, similar to below?
Nachricht 5 von 31
Sahay_R
als Antwort auf: ToanDN
You got it!
This is the .dwg that needs to be hidden
And this is the MEP linked file
Rina Sahay
Nachricht 6 von 31
I always find this list most valuable when trying to troubleshoot an issue of this kind. If it doesn't help you, perhaps you'll discover a 34th reason. If so, add it to the list.
https://www.revitforum.org/tutorials-tips-tricks/441-cant-see-view-heres-33-reasons-maybe-why.html
Nachricht 7 von 31
Sahay_R
als Antwort auf: barthbradley
Barth - we need another list for my situation - List of Objects That Disappear.....
Rina Sahay
Nachricht 8 von 31
Sahay_R
als Antwort auf: Anonymous
OMG!!!!!
When I go to crop the view the lights DISAPPEAR!!!! It's the CROPPING!!!! Smiley (überglücklich)
Calm down, though. Now that I know this, I still don't know how to fix this.....
Rina Sahay
Nachricht 9 von 31
So there is a "break point" where the MEP model disappears.
What is getting hidden at that point? Is there a way to trick it? Does it relate with how the lighting fixtures are made or hosted? does this affect all elements of the MEP model?
Nachricht 10 von 31
Sahay_R
@Anonymous
When I crop the view, the MEP model disappears. When I hit the lightbulb it reappears but is NOT pink.
Rina Sahay
Nachricht 11 von 31
I've seen this happen. Go to family and I'll bet there is a model line extending away from origin of the geometry.
Nachricht 12 von 31
Would making the crop slightly larger help? Just out of curiosity
Nachricht 13 von 31
Sahay_R
Which family? Selecting the crop region does not take me to a family....
Rina Sahay
Nachricht 14 von 31
So it is not because of turning off a DWG?
Nachricht 15 von 31
Sahay_R
@Anonymous
No such luck.....sighhhh....
Rina Sahay
Nachricht 16 von 31
@rsahayUZMK9 wrote:
OMG!!!!!
Maybe I'm misreading...Isn't the issue about lights disappearing when you crop a view? That's what you said here with a smileyvery-happy emogy.
Nachricht 17 von 31
Sahay_R
@ToanDN
When the view is cropped and I turn the linked .dwg off, then the lights on the linked MEP disappear
When the view is uncropped and I turn off the linked .dwg, then everything works beautifully. However when the view is cropped then the lights from the linked MEP disappear.
Definitely a WTF moment.
Rina Sahay
Nachricht 18 von 31
What happens if you crop the view but turn on the DWG?
Nachricht 19 von 31
LOL
...sorry, @Sahay_R, I got interrupted. What I was laughing about was @ToanDN post. But, seriously, what is the issue? I kinda lost track.
Nachricht 20 von 31
Sahay_R
@ToanDN
When I turn on the .dwg and crop the view the MEP stays visible.
When I turn off the .dwg and crop the view the MEP disappears. Interesting.
(wait, didn't we just come around full circle here??)
@barthbradley
Point finally understood - I could get into the light family and have. Unfortunately, fixing and reloading it is out of my purview as that area belongs to the MEP guys.
(stop laughing for a bit, get serious and constructive - LOL!!!!)
Rina Sahay
