@barthbradley wrote:
Do you realize that your reply posts contain over 100 letters? It took more work to type those 100 letters than it would have taken to cut 100 blocks using Cut Geometry with Multiple Instances checked.
thank you again for replying
i think that cut multiple doesn't work in my case cause
- if i start by selecting one block, then the beam " to cut the block" 👌, then selecting another block , doesn't seem to work
- if i start by selecting the beam , then the block "to cut" 👎, i will get a hol in my beam, if i select other block they
keep making hole in the beam according to the block i click on , and that's quick but not what i want to do.
anyway , i think i'll do it one by one before copying the next floor,
thank again
