I have created standard void extrusion but I would like to cut diagonally it's edges and I don't have any idea how to achieve it.
I tried to use void sweep but it's not the result that I want (I want to cut the edges and not to rotate).
Any idea?
Please see the attached images.
Thank's
Yuval Dolin.
instead of using void extrusion? you can create different extrusion form and use join geometry. thanks
Although I would agree with Ennujozlagam to rather model the positive than the negative, you can model the void using three plan extrusions.
@Anonymous wrote:Although I would agree with Ennujozlagam to rather model the positive than the negative, you can model the void using three plan extrusions.
Is that a void... ?
Sorry, the image was not as clear/confused me a little. Added below image to help illustrate your point.3x plan void extrusion
