Cut Void Edges
7 REPLIES 7
Message 1 of 8
yuvdal
647 Views, 7 Replies
Cut Void Edges
I have created standard void extrusion but I would like to cut diagonally it's edges and I don't have any idea how to achieve it.
I tried to use void sweep but it's not the result that I want (I want to cut the edges and not to rotate).
Any idea?
Please see the attached images.
Thank's
Yuval Dolin.
7 REPLIES 7
Message 2 of 8
ennujozlagam
in reply to: yuvdal
instead of using void extrusion? you can create different extrusion form and use join geometry. thanks
Message 3 of 8
in reply to: yuvdal
Although I would agree with Ennujozlagam to rather model the positive than the negative, you can model the void using three plan extrusions.
Message 4 of 8
martijn_pater
Is that a void... ?
Message 5 of 8
in reply to: martijn_pater
No, its a solid to illustrate the modelling.  Here it is as a void.
Message 6 of 8
martijn_pater
Sorry, the image was not as clear/confused me a little. Added below image to help illustrate your point.
3x plan void extrusion3x plan void extrusion
Message 7 of 8
Exactly - thanks fo that.
Message 8 of 8
yuvdal
Great solution, thanks!
Forma Design Contest
