05:18 AM
- Mute
- Permalink
- Report
In a plan view I want to have a black solid cut pattern on my walls. When I use the View Template to show walls with a black solid cut pattern, the patterns also applies to the mullions in the Curtain Walls (since they are walls) However, I want the mullions to have a white cut pattern. Is there I way i can work around this and make the mullions white?
