I tried to install REVIT 2017 and had some problems,
the instalation crashed a lot of times and after a lot of tries I installed Revit, but it wont start.
A click on the icon to open and imidiatelly windows says it stop working
I tried uninstall but it dont let me
I would try the Autodesk Uninstall tool first (if it is available). Search or browse your installed applications under Autodesk > Uninstall Tool. See if Revit 2017 appears in the list, if so check it and click Uninstall.
If that works I would attempt doing an install again to see if it can complete successfully.
If you are still having issues, it might be worth registering your software for Up & Ready Support:
http://www.autodesk.com/support-offerings/up-and-ready
Thank you,
If you installation have failed several times, it has most likely not been installed correctly this time either.
Try running it as administrator and if it doesn't start I would do a clean uninstall and install it again through the Virtual Agent.
You can use these articles:
If you have questions let me know,
Best Regards
