Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Cut Geometry of Roof
Hello. I am trying to Cut a Roof. I am using a wall to do it but for some reason I cannot cut the roof.
Help appreciated.
artejon
You cannot cut a roof like that, edit it's sketch and align it's edge to a face of a wall.
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
Revit_Whisperer
I'm afraid the roof can't be cut that way with a wall....in order to cut to roof flush with the face of the wall you will need to do one of the following:
  • Edit the roof boundary so the it ends at the face of the wall and remove the slope on the end intersecting the wall
Or
  • From the Architecture tab, Opening panel, select vertical opening and define the part to be removed.
Aside from the already mentioned methods, here is another way.
Revit_Whisperer
Nice @ToanDN ...it's always good to have options!
