HI
I use revit 2016 and struggle with the following:
* Elevations shows as sections ;
* The roof does'nt show the beams, purlins and roofplates in the section;
* struggle to put roof material on the roof;
Can you please help solve this.
Cornelius
I attached a quick video related to your questions...but the quick answer is below
If the elevation cut plane is inside of your model, then it will appear as a section. To fix, select the arrow part of the elevation and move the blue line outside of the model.
If you have not modeled the roof structure and just have the Roof element, you will only see the thicknesses of the roof layers, not the actual components
To add a material to a roof you must select the roof, Edit Type, select the layer you want to assign a material to and open the material editor to assign a material or create one to assign.
