By mistake, I posted this originally in the A360 Rendering Forum when it should be here!
Anyone know if it is possible to add a 'Wall Sweep', in this case using a coping profile, to the top of a wall that slopes upwards?
Gelöst! Gehe zur Lösung
Gelöst von artejon. Gehe zur Lösung
You can create in-place component as a sweep following the edge of a wall, go to Architecture>Component>Model In-Place.
Hi @IMCornish,
i agree With @artejon use in place family.below is a Youtube link explaining the process.
https://www.youtube.com/watch?v=yRNsSHH27UE
If this is the only way of achieving it then fair enough. I have accepted your suggestion as the solution but as with many things 'Revit' it is a workaround and not a real virtual building component, sadly.
Thanks for your interest and help.
