I'm trying to create a custom north arrow with text that follows rotation angle but doesn't rotate, however, I'm getting stuck at the very first step.
This is the tutorial I'm following:
https://www.youtube.com/watch?v=vrI7WhW6FTU
After creating a Reference line, adding angular dimension and assigning a parameter to it, it only works for angles 0 to 180°. As soon as I try flexing above 180° I get "Constraints not satisfied". This is just the Reference line itself, I didn't even "attach" any geometry to it.
Family attached.
Solved by Prvoime. Go to Solution.
@ToanDN wrote:Try this.
This is a very interesting solution! However, I found another tutorial and it uses the same process as the one I previously linked. So I went over the steps again, and again, Constraints not satisfied.
Then I inserted it into a project, for the heck of it because that's what they did, and even though it breaks apart in Family editor, it works inside a project!
No idea how or why, but there you go.
Also thanks @FAIR59 for the idea.
