Custom Elevation Tag
PhilvK
Advisor Advisor
PhilvK
I am trying to edit the typical building elevation tag and can't figure out what the correct sequence is for editing the multiple families that make these tags up, and where / when to load them back into the other families in a manner that will allow the changes to appear in my drawing. I also cannot figure out how the Additional Settings > Elevation Tags setting relate to this process. The Youtube videos I've finding are from many years ago. Does anyone know of a more current video that can be located that can help me sort this out?
Hi, @PhilvK , here is the hierarchy:
Elevation Types (select a elevation view tag or select the view on the project browser)
Elevation Tags (you cannot load; to set these, go to manage > additional settings > elevation tags)
Elevation Marks (the loadable families you see on your project browser)
So you must create/edit your elevation marks in the family editor, then create/edit elevation tags to assign those elevation mark families and final, assign the elevation tag to a elevation type.
Hope it helps.
