Best way to duplicate a wall opening?
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
paulmjackson
1854 Aufrufe, 9 Antworten
I have created a wall opening using Model In-place > Generic Models > Create > Opening, then selecting my wall.  I would like to reproduce this opening shape for other walls, but I can't seem to load the opening family (or is it a type?).  When I hover my cursor over the opening shape, it shows 'Generic models > cutout > cutout'.  When I try to load via Component > Place Component > Load Family, I can't even find the Generic Models folder.  A search of my drive doesn't turn up any files with the name of the family.  Would it be better to model a group of extrusions, then duplicate that as needed and use the cut tool?
9 ANTWORTEN 9
Nachricht 2 von 10
paulmjackson
als Antwort auf: paulmjackson
I should add that the cutout shape shows up in the Project Browser, but I can't figure out how to bring it into the project.  I apologize for the trivial question!
Nachricht 3 von 10
In place models only exists in the project.  You have to copy it from one place to another.  The copies however don't relate to the original, if you edit one the others won;t get updated.  In-place models is nor recommended to you are going to have multiple instances placed.  You should have created a family and load it in then  you get it from the project's family browser and place it multiple times.
Nachricht 4 von 10
paulmjackson
als Antwort auf: ToanDN
Thanks for your response!  So I should make a family for the wall, with the openings in it?  In searching for how to do this, I came across the following forum post, which states "Walls are system families and you can't create new families." (https://forums.autodesk.com/t5/revit-architecture-forum/how-can-i-create-a-wall-or-a-floor-as-a-fami... Indeed, there appears to be no wall template for families.
Nachricht 5 von 10
No. Make a family as a window or a door for the opening.
Nachricht 6 von 10
paulmjackson
Ah... that makes more sense.  Thank you!
Nachricht 7 von 10
bin
In Revit family folder under door and window there are Structural folder, where you can find the door and window opening.  Load them and create the size you need.
Nachricht 8 von 10
If your opening is rectangular then the easiest is to use the built in wall opening tool.
Nachricht 9 von 10
bin
als Antwort auf: Anonymous
Can you demolish a wall opening?
Nachricht 10 von 10
als Antwort auf: bin
Well you can't demolish something that doesn't exist.  The opening takes on the phase of the wall, so if you demolish the wall then the opening goes with it.  You can fill the hole in with a new wall if you want.
