Custom arrow family + Spot Slopes
Sahay_R
Mentor Mentor
Sahay_R
Is it possible to combine the 'smart' spot slopes with a dynamic customizable arrow that I have created as a line based detail family? Or would the better way be to customize the leader parameters for the Spot Slopes?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
I think it would the better if you customize the leader parameters for the Spot Slopes, Since it has the parameters to modify.
Sahay_R
Thank you. That worked!
Rina Sahay
Radish_G
Hi @Sahay_R.,
If you don't mind, please share the family.
Regards
Radish G
@Radish_G wrote:
Hi @Sahay_R.,
How do you want it to look?  Spot slopes and leader arrows are both system families, nothing to share.
Sahay_R
@Radish_G - @ToanDN  is absolutely right. The accepted solution by @Anonymous  pointed at modifying parameters. Please experiment with different parameter values to get the effect that you want.
Rina Sahay
@Sahay_R @ToanDN @Radish_G
Hi, I have added a short screen cast related to this, will be happy if you check it out.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/screencast/Main/Details/7f4...
Thanks.
