Is it possible to transfer individual materials from one Revit Project to Another, instead of the entire material library?
Gelöst! Gehe zur Lösung
Gelöst von Sahay_R. Gehe zur Lösung
Create an object with the material applied.
CtrlC and CtrlV into another project.
Thank you very much for your contribution. We have been dealing with this issue for a day, can't believe it was this simple.
This works unless a material by that name already exists in the destination project. Then you will have to change the name of one of the materials.
this worked, to point. The choice appeared in the materials selection, but the colour wasn't adopted. The asset isn't shared, which is supposedly good (the little hand shows "0") but the asset is locked.
