Curve Mass not showing Edges?
pearlofsadness
pearlofsadness
Hi all, was just wondering if there is a way to show curve massing with edges? As I would like to view it in my Hidden Line style.
Shaded Style showing CurvesShaded Style showing CurvesHidden Line not showingHidden Line not showing
alan_eu
Hi @pearlofsadness
Did you try to turn the ambient shadow ON? Or even the silhouette lines would help you...
4BEWhnb
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou 🙂
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! 🙂
alan_eu
Maybe you should try this mode also:
qPQjW31
pearlofsadness
Hi Alan,
I tried all the tips u gave but I actually just wanted Hidden Line Style... I am still baffled as to why edges doesn't show when I have a curve/cushion massing form...
But I can compromise, so I am actually using V and U grids currently to make it seem like its own edges... But is there a way to like change the U and V grid colours after completing the Family and Mass? Also, how would I be able to make the "Cushion" Transparent again after using this method? Coz now it is like a solid colour with the grids... Because I kind of used the regular Rectangle pattern..
Applied U&V Grids and a Rectangle Pattern on the Cushion FamilyApplied U&V Grids and a Rectangle Pattern on the Cushion FamilyNow the massing is no longer having any transparency and I want the lines to be Black..Now the massing is no longer having any transparency and I want the lines to be Black..
syman2000
Sadly object with 3d parabolic arc and curve won't show in hidden and consistent view regardless what you do. Even a sphere won't show up edges in hidden line. You have to add your own lines in the family or set it to shade/realistic to make it show.
pearlofsadness
Hi, may I please know how would u add ur own lines in the family?
syman2000
I just use spline and pick the 3 points
