Curve dimension
Curve dimension
sabamail65
Message 1 of 9
Curve dimension
sabamail65
How can I dimension between two curved lines?
Replies (8)
Message 2 of 9
RDAOU
Like this?
Dimensions strings need something to snap to...when lines are not parallel to lock on to their surface or axi, you would need to improvise a workaround. Example:
  • Use the Split tool to split the curved Line(s) or Wall(s) at the point(s) you need to measure to
  • Use tab to get the dimension string to snap to the end point(s) of the split segment
Message 3 of 9
Between??? We are going to need to see a screenshot. Or a more robust explanation.
...this?
Message 4 of 9
If you want the shortest distance between 2 arcs, turn on center and draw a line though, split the arcs as @RDAOU suggested at the intersection.  Then delete the line.
Message 5 of 9
You can also place a shortest dim between to arcs without splitting.
https://knowledge.autodesk.com/community/screencast/6bcee68f-2453-48bd-8c88-9bcdef05d115
Message 6 of 9
sabamail65
Thanks for the previous answer. I had another question. What should I do if I want to measure between a curved line and a point or straight line?
Message 7 of 9
mauricio_mssf
For aligned dimension, the tool always works perpendicular, in the case of a curve it goes to the tangent, so if you want to determine directions, just make an auxiliary line (I used a detail line) just to tell the tool the perpendicular direction, put the dimensions and then delete the auxiliary line.
If you want to use the arc length dimension, you need to select ther arq then the begin and the end, to say "i want dimension that arc, from here to there".
https://autode.sk/2Y5kSxn
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Message 8 of 9
Same method. Dimension from the center point the desired point or the line, then edit witness line to add the arc and remove the center point witness.
Message 9 of 9
RDAOU
@ToanDN
Were you too shy allow screencast to record the 23 mouse clicks needed to place a dim without splitting? 😆
