This is a problem I've had cropping up more and more frequently lately, especially on walls and joins with weird angles, but i will often have curtain walls clipping through walls that I'm trying to join them to in order for them to join to another wall. I've also had where if i try to extend a curtain wall to be a few inches off of the face of a wall, or create a gap between the end of a curtain wall and start of a different wall, the curtain wall will automatically snap to the other wall, even when I don't want it to, sometimes jumping several inches (6+") to do so. Is there a way to prevent this behavior, or is this a known bug?
For reference, this is a situation where i am trying to have the curtain wall butt up to the face of the angled wall (extend curtain wall to solid red line), but instead the curtain wall is extending further in order to join up with the wall on the other side (dashed red line). obviously, this is incorrect, but i cannot for the life of me get the curtain wall to stop automatically snapping to random walls, even when i specifically tell it not to. Even turning off joining for the other wall doesn't work, the wall will no longer join to any other standard walls, but the curtain wall will STILL try to connect to it.
Assuming I'm understanding your design intent --
You need to end the Curtain Wall with an L-Corner Mullion. That will require a Curtain Wall corner return of a very small length.
Do these screenshots help?
Select the curtain wall, right click on the end grip and Disallow Join.
Toan Nguyen
@mbootsUJVFW wrote:
... the curtain wall itself is not connecting to the wall that I want it to...
Connect how?
Literally as I said, the curtain wall is not connecting/joining to the intended wall. I'm referring specifically to the actual curtain wall hosting object, not the individual panels or mullions, which is not joining correctly to other walls. In this case, it connected to the standard wall on the other side of the wall that I want it to connect to. Basically, when I use the trim/extend elements command, I want the curtain wall to extend to the face of the more vertical wall (the solid red line on wall A). however, whenever the curtain wall gets close, it instead snaps through wall A to instead join to the centerline of the wall on the other side (the dashed red line in wall B). I do not want this happening, i want it to connect to the face of wall A, but not only does it ignore wall A to connect wall B, it refuses to disconnect, and i have to move the end point of the curtain wall >6" away from either wall in order to get it to disconnect. And if i try to reposition it, as soon as it gets close, it just snaps back to wall B again. Using trim/extend elements does nothing, using the wall joins command doesn't work (it'll disconnect the two normal walls A and B, but not B and C), telling the curtain wall not to join doesn't work.
If you don't want to Disallow Join after-the-fact, you can simply change the Join Status of the Wall on placement.
Regarding my Mass comment: that was just a Hail Mary pass.
Stretch the curtain wall away from the intersection so that you can correctly highlight its end grip to disallow join. Then stretch it back to the intersection.
Toan Nguyen
You're not by chance talking about moving the Curtain Wall's justification point; are you?
