Dear all,
Again I have questions regarding curtain walls.
Between the wooden mullions there is a 3000mm x 3000mm space, so I would ideally like to have three panels of glass with a width of 1000mm each. Is it possible to create this, and would somebody be able to explain to me how I might go about it?
Thank you VERY much in advance, Nina
Solved by ToanDN. Go to Solution.
You can set fixed number, then select the curtain wall and enter the number in the properties. You can tab select any panel, unpin if it is pinned, and change to a different type (for example, glass to solid).
Thanks @ToanDN! ... that makes a lot of sense! However, when I do that, something strange happens to the panels.. I have attached a picture to show you.. do you know why this has happened?
If I click delete, then it becomes more chaotic :L
Select all vertical grids and pin them, or change them from Independent to Dependent fromm properties.
