Curtain wall problem
3 REPLIES 3
stevensonJQWEF
288 Views, 3 Replies
Dear all,
As shown in the pictures I am haveing a problem when I try to change the vertical grid from 'None' to 'Fixed number'.
On the default 'none', there is no problem... however,  I would like to only have three glass panels.   When I change to fixed number, the whole arrangement turns completely random and I dont know why or how to change it.
Could someone perhaps provide me with help here?
THanks in advance
Labels (1)
3 REPLIES 3
Sounds like you have Independent Grids. Make your Grids Dependent.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-M...
...just to be clear: remove Independent Grids if you want to use Type Driven (e.g. Dependent) Grids.
BTW: if they are Independent and you only want 3 Panels, then leave Layout set to "None" and pull an Equality Dimension between 4 Grids.
thanks @barthbradley !
Forma Design Contest
