Dear all,
As shown in the pictures I am haveing a problem when I try to change the vertical grid from 'None' to 'Fixed number'.
On the default 'none', there is no problem... however, I would like to only have three glass panels. When I change to fixed number, the whole arrangement turns completely random and I dont know why or how to change it.
Could someone perhaps provide me with help here?
THanks in advance
Solved by barthbradley. Go to Solution.
Sounds like you have Independent Grids. Make your Grids Dependent.
...just to be clear: remove Independent Grids if you want to use Type Driven (e.g. Dependent) Grids.
BTW: if they are Independent and you only want 3 Panels, then leave Layout set to "None" and pull an Equality Dimension between 4 Grids.
