Curtain Wall - Mullion Miter
audi.capellan
Message 1 of 14
audi.capellan
Hi Everyone,
I wanted to combine different mullion depth and wanted to have a mitre joint but I can't find any solution that works. Does anyone have a similar experience? I have attached a picture to show the issue for reference.
Replies (13)
Message 2 of 14
PrathapSekar
Hi @audi.capellan, I can't understand the orthogonal image you posted.
how about the first two mullions as shown in your image, seems like connected as you expected. Please post a clear image.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
Message 3 of 14
audi.capellan
I need the bigger mullion to mitre join with the small mullion. Meaning, it  should join a nice corner as attached image.
Message 4 of 14
Viveka_CD
Hi @audi.capellan
Can you share the file to test further?
From the image, it is not clear what you are trying to achieve.
Message 5 of 14
Viveka_CD
@audi.capellan
Also, see the knowledge article - About Mitered Mullions on Curtain Walls
Looking forward to testing your file.
Message 6 of 14
audi.capellan
Hi Viveka,
Here is the file for your reference and thanks for trying to help.
Audi
Message 7 of 14
Viveka_CD
Hi @audi.capellan
Thanks for sharing!
Can you also let me know the version of Revit you use and if your updates are in place?
Message 8 of 14
audi.capellan
@Viveka_CD wrote:
Hi @audi.capellan
Thanks for sharing!
Hi Viveka,
I am using Revit 2018.3.1.2
Audi
Message 9 of 14
Viveka_CD
Hi @audi.capellan
Glad to hear that you have the updates in place.Smiley Happy
Here's a quick workaround to 'join' the different mullions
1. Create a mass and pick the top and front faces to generate one curtain system. Add the mullion by picking the grids. Use two rectangle profile but with a different dimension. The created mass will become the 'corner miter' to join the two different mullions
2. Create an in-place component - generic model, select the face of the mullion and create a model by extrusion as shown below:
Let me know if this works for you and if you have additional questions.
Please select the Accept as Solution button if my post solves your issue or answers your question. Likes welcome!
Message 10 of 14
audi.capellan
Hi Viveka,
Thank you for posting your solution. I have a question: Do I create this mass once and automatically updates all mullions with the same issue? What I hope to achieve is not to do a manual copy and placing this mass to the rest of the mullions that has the same mitre issue.
Audi
Message 11 of 14
PrathapSekar
@audi.capellan
Have you tried with corner mullion families? I'm not that much aware of it.
Message 12 of 14
Viveka_CD
@audi.capellan wrote:
Hi Viveka,
Audi
Hi @audi.capellan
I see what you are saying. I wondering if we can do a custom mullion profile (mass+ 2 different mullion depths)_and then load this family in the model.
Message 13 of 14
audi.capellan
Hi Viveka,
Thanks for the suggestions. I will take this as a workaround and was hoping this can be incorporated in the future developments of the curtain wall.
Audi
Message 14 of 14
Viveka_CD
Sure @audi.capellan you are welcome to post this to the Ideas forumSmiley Happy
Please post when you have a chance and paste the link here.
