Some of the structural walls are not visible in the Floor Plan View,But Visible in the 3D View.I have given cut plane as 1500 mm.The wall height is floor to Floor.
Hi @Anonymous
Thanks for posting on the Revit Architecture forum!
Please see this AKN article: Why is the Structural Wall not visible in floor plan?
Please select the Accept as Solution button if my post solves your issue or answers your question. Likes welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi @Anonymous
Did the recommendations help with your issue? Are you seeking additional information?
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you!
Viveka CD
