Curtain wall, Make continious horizontal mullion which is behind vertical mullion
Burak_Baran
Burak_Baran
I would like to make horizontal mullions behind the vertical mullions as my purpose is making room seperator profiles with it,but when I try to make continious horizontal mullions the vertical mullions having a break ,
Is there any solution for that?
Felipe_DeskGraphics
Hello! In the edition box you have an option to choose which will be continous. Try changing to vertical continous and see if it solves the problem.
Felipe Mantuano
BIM Specialist | Civil Engineer | Revit Specialist
Burak_Baran
Hey,I tried that and unfortunately I still have same problem.
What about sandwiching different Curtain Walls together? Too easy?
Burak_Baran
I did in that way actually and it kinda works for me but I would like to know is there any possibility to make it because the combined curtain wall needs extra attention if I would like to change place or size as I am doing it in multibuilding facility.
You can do it in one curtain wall if you use panels in lieu of vertical mullions.
Burak_Baran
can you detail your comment as I didnt get what editable element you will put instead of panel?
