Creating True North arrow showing angle from North
7 REPLIES 7
Message 1 of 8
Sahay_R
6987 Views, 7 Replies
Good afternoon,
I have been building a True North arrow, with rotation parameters. Currently I have it set where the tag displays the angle going East from Project North (up). I had tried to add it to the View Title with the objective of changing the arrow rotation as needed, but that didn't work. So now my plan is to just load the arrow to my template where it can be used as needed especially by the Landscape guys.
My concern is the True North angles that are going West. Would it be acceptable to display True North values between 0-360? If not, would there be a formula on the lines of If Rotation > 180, then Label Value = 360 - Rotation? Would I need another Label which displays the angle value as W? As you can see, my current Label has a suffix of E, so it displays all angle as going East. Should I get rid of the suffix?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
7 REPLIES 7
Message 2 of 8
rudi.roux
in reply to: Sahay_R
Hi @Sahay_R
Have a look at THIS POST which served as a solution for another community member regarding "Smart North Arrows"...
I hope this helps! Smiley Happy
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
Message 3 of 8
Sahay_R
in reply to: rudi.roux
Uuuhhhh Rudi - that post was for this very same problem! Now I am trying to take this arrow beyond that level.....
Smiley Very Happy
Rina Sahay
Message 4 of 8
Can you upload the family?
Message 5 of 8
rudi.roux
hahahaha... Smiley LOL Apologies, only noticed it now. It's a bit late now (hence my mess-up), but I'll have a look tomorrow. Share the family?
Rudi Roux
LinkedIn
Message 6 of 8
RDAOU
@Sahay_R
I didnt understand what the question is lol ... if it is acceptable to display angel from true north 270 degrees? I would say yes there is nothing which stands against that...
If you want to roung it always to an angle between 0 and 180 it is also possible using an intermediate parameter which controls the angle using an if statement; example... Angle B = if(Angle A>180, 380 - Angle A, Angle A)
But I personally dont see any issues with an angle 227! well as long as the tag won't end up dispalying 3477 degrees lol ie: 227
PS: And btw, project north is the simplest thing which should come to ones mind and it shouldn't really be complicated and automated or smart or whatever!! don't make your life too hard on a generic annotation tag 🙂
Message 7 of 8
Sahay_R
No problems, Rudi!
Absolutely, gentlemen!
Once again, it could go without displaying the angles, but why not push it a little further? LOL!!
Rina Sahay
Message 8 of 8
Alfredo_Medina
I think that showing the angle in the North symbol is not necessary. The method that I described in that other post, about copy-pasting the value of the angle from the Project Base Point into the Rotation angle of the North Symbol family provides an accurate rotation for the arrow in the symbol, which can be saved in the type that is used in floor plan views. For the site plan, you could create another type, with the rotation angle as zero.
Forma Design Contest
Technology Administrators
