Top Rail/Handrail not available
4 ANTWORTEN 4
Nachricht 1 von 5
1229 Aufrufe, 4 Antworten
I'm trying to build a template and started from a blank file.
When I try to set up a railing type, it will not allow me to use a top rail or hand rails.  The type properties window will not allow me to change Top Rail from 'no' to 'yes' and nothing happens when I click '...' next to either handrail type.  I have loaded railings with all these components into my template, but when I try to edit their top rails or handrails, the family breaks, and I have the same issue.  Is this a bug others have noticed, or am I missing something?
Ben
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Save a copy of the file, purge everything except for Railings/Top/Hand Rail types, and upload it.
Nachricht 3 von 5
Do you have a Top Rail Family Category with Rail Types loaded into your project?
Nachricht 4 von 5
FGPerraudin
By any chance, would you be trying to modify a family that is nested in a group from outside of that group?
If the case, first enter your group and then modify,
Or select your railing type in the navigator and edit its properties by right-click> Type properties...
Some options are disabled when proceeding that way...
And for good reasons!
François
Francois-Gabriel Perraudin
BIM management and coaching
Nachricht 5 von 5
OK, false, but interesting, alarm...
I found that because I did not have an instance of the railing modeled in the project (it's a template, so I was modifying the railing type just out of various type properties in a blank file) I was not allowed to select any options.
I popped in an instance of that railing, and full functionality returned.
Thanks to all for the comments!
