Creating ICF Wall Look
Hi I currently work for a dimple membrane company and we would like to render some images of our dimple board applied on an ICF wall.  The problem is how do I create a wall to look like ICF, meaning I would like to show the lines of each ICF block (normally 1' 4" tall, by 4' long) as well as the lines that show where each web/tie is located (normally 8" or 12" depending on manufacturer).  Image below is what I have done so far.3D Intro View.png
Maybe Tile Procedural Map?  Probably the direction I would go.
Procedural Maps | Revit Products 2018 | Autodesk Knowledge Network
