Creating handrail on sloped and curved structural wall
O_Shaher_eg
Message 1 of 9
O_Shaher_eg
Hello everyone , I am trying to create handrail on a sloped and curved structural wall. The handrail does not follow the path, resulting in incorrect alignment.
Specifically, the handrail segments don't align properly with the wall . Attached are screenshots showing problem areas. Anyone have any idea.
Replies (8)
Message 2 of 9
Model a roof on top of the wall and use it to host the railing.
Message 3 of 9
vitorbortoncello
Use sweep
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Message 4 of 9
Is the top of the slanted wall level?  If so, just place the railing on the level that is at the top of the walls.
Message 5 of 9
O_Shaher_eg
Thank you all for reply but be noted that the wall is sloped not only circular.
Message 6 of 9
O_Shaher_eg
The wall is sloped
Message 7 of 9
O_Shaher_eg
Could you please provide the steps to create Railing by sweep ?
Message 8 of 9
azad.Nanva
use the ramp:
or make it as the generic model.
Message 9 of 9
vitorbortoncello
use swept blend, select the wall line as path and create the profiles..it works best if your railing is solid. You can model the vertical parts as extrusions...
