- Mute
- Permalink
- Report
Obviously, there are different 'sheets' for different aspects for construction docs.
But, if you need to put a demo plan, a new plan, and an existing plan on one sheet, how are the same, but different floor plans saved so they can be placed on the sheet. This sounds probably confusing, but if you create a floor plan at, say, the level 1 and it is modified, it will modify everywhere. So there seems to be need to create separate versions of the same floor plan unless there is a clever way of doing this.
