creating a window family with odd height jambs
Message 1 of 14
Hi. Can anyone help ? I want to create a parametric window family but I want my window to have uneven height jambs (i.e. it has a sloping head). The window metric template doesn't seem to offer this capability.
Replies (13)
Message 2 of 14
jdiala
See screencast. I just put the wall opening but the idea is there.
Message 3 of 14
Many thanks for your reply. However, what is a 'screen cast' and where do I find it. Thank-you
Message 4 of 14
Oops. Sorry. I click on the blank screen ! Got it. Thank you once again.
Message 5 of 14
So sorry JDiala, but from some reason, I can't open your screen display explanation a second time. Any chance you could re-send ? So sorry
Message 6 of 14
Keith_Wilkinson
@Anonymous - Attached is a 'window' family (RVT 2015) with a sloping head - I've adjusted the Opening cut profile to give me the slope and then nested in a separate family that actually generates the window geometry (I generally find this approach more robust).
Hopefully you can pick it apart to understand how it's done.
HTH
K.
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
Message 7 of 14
Keith. That's really helpful. Thank-you
Message 8 of 14
jdiala
There is no on screen explanation on the screencast. In order to achieve on what you are looking for, you need another reference plane to control the slope of the window. I would also use a family to be nested for your window as Keight suggested. You don't really need a reference line per my my first video. I just did it just to show you that you can also use an angular parameter to control the slope of the window (which I didn't). On the second video (this post), I didn't create the reference line yet I still achieve the same result
Message 9 of 14
Hi. Thank you for your replies. I have created the wall opening with splayed head successfully. However, the sloping top-part of the EXTRUSION won't follow the sloping top-part when the width is altered. Any thoughts ? I wish I could attach a screen print or attaching a file but my work internet access seems to be blocking me doing this !
Message 10 of 14
Trying again to attach a pdf screen shot of the problem I'm encountering
Message 11 of 14
Keith_Wilkinson
I'll assume you have created your extrusion in elevation.
Edit the profile and click on the Align Tool.  Now move over the top end of  one of the vertical lines and press tab until you see a blue dot at the end of the line, click this then click on your reference plane and finally click on the padlock to lock it in.  Repeat for the other side.
This *should* sort you out but hard to be sure with seeing exactly what's happening.
cheers
k.
Maimonides
Message 12 of 14
Not sure what I'm doing wrong but when I try and add a width peramter, i get an error message as the enclosed screen shot. Any advice ?
Message 13 of 14
See if you have any dimensions for the same reference plans on other views and delete them.
Message 14 of 14
jdiala
By default there is already a width parameter on the windows template so there is no need to add one.
Go to your reference level view and you'll see it.
