Creating a site topology with point cloud
I am struggeling with this problem all day now. I downloaded a point cloud file showing the topology of the site. I finally converted this one into Recap. Then I saved/exported it as a .txt and a .csv file because those are the only ones I could pick when I go to (in Revit): Massing&Site --> Toposurface --> Create from Import --> Specify Points File. Afterwards when I try to take them, Revit always freeze and stopped working. I think it is because the files are too large (500.000KB).
But when I try to Insert --> Point Cloud and take the same file as a .rcp it works and in the 3D view I can see the topology. But they are still points and I need a surface (like for the ground). It would be good to see the topology lines in the floor plan too, but thats not the important thing here.
OR:
my other thought is: I have got a 3D file of topology lines in a 50cm distance. The file was downloaded in .asc (only option). How can I get this one into an .csv or .txt file (that is not empty) so that I can open it in Revit?
Does anybody know what I can do?
Thanks in advance and best wishes,
Julia
post your csv file for us to examine
Thanks for your answer. The file is too big to put in here but I created a link where you can download it:
https://we.tl/t-kvjDl3Wcnf
