I have a problem with my Revit Window (picture below). Somebody know what's happened? I am learning Revit and i really need full view.
I would be grateful for help.
Ana
Interesting. I've had something like this happen to me three or four times in the last two weeks or so (Revit 2018.2 only). I can only correct it by closing and restarting the program. I haven't investigated why it's happening.
Following...
Are you using any Windows display scale more than 100%?
Steve Stafford
hello, have you try to switch off your use hardware accelerations, see if helps and check also your window display scaling setting try to adjust, as suggested by @SteveKStafford. thanks
Coincidentally, I just opened Revit and got my issue that I was likening to the OP's issue.
Any ideas Guys?
Took 2 restarts this time to correct the UI. This is a recent development and probably the 5th time it has happened in last two or three weeks.
18.2.0.51
20170927_1515(x64)
2018.2
Win 7 Pro SP1
hello, i also experienced this sometime ago, i update my graphics card driver to the latest the problem go away..just saying. thanks
