URGENT_ REVIT TROUBLES
2 ANTWORTEN 2
Nachricht 1 von 3
190 Aufrufe, 2 Antworten
With Large Files - what is the best process to obtaining continuity.
From a AutoCad background- the interface is similar but the operation is a little different
Also how do you set up a systems of families
How do you build families as new components for a specific project.?
Thank you all help would be appreciated
Diana
2 ANTWORTEN 2
Nachricht 2 von 3
Avaris.
als Antwort auf: Anonymous
Just purge objects you don't need to reduce file size, also don't leave to much design options open.
I think that after reading this 10-part series, you have a pretty good understanding of Revit families
Nachricht 3 von 3
"With Large Files"???
My suggestion would be to start small and not "urgently"; and certainly not with a conversion of large AutoCAD files/projects in one fell swoop.   Combining a big project with a steep learning curve is a recipe for disaster.
Our transition to Revit took 22 months.
