Create walls whit sweep
gustavosanmartin
Message 1 of 11
gustavosanmartin
Replies (10)
Message 2 of 11
Wall sweeps are always cut at the right angle. Use a void to trim them.
Message 3 of 11
like this?
Just make the Wall height equal to ridge height, complete the sweeps all the way to the top, and then Attach Top of Wall to Roof.
...and then JOIN Roof and Sweeps.
TIP: Use MULTIPLE Join. Pick Roof first and then each Sweep one by one.
Message 4 of 11
gustavosanmartin
Message 5 of 11
Do you have a Roof?
Message 6 of 11
ennujozlagam
post that elevation file here so we can check. thanks
Message 7 of 11
Hi,@gustavosanmartin
If you are not success in Sweep then try Reveal, Create a wall groove profile and use as reveal in wall or create a model in place Wall void component then cut this extra part.
Thanks.
Please click " Accept as Solution" on the posts that helped you, so others in the community can find them easily.
Message 8 of 11
gustavosanmartin
THANK !!!!!   now I could do it
Message 9 of 11
gustavosanmartin
Is it possible that you can show how to do it this way? attach the file
Message 10 of 11
check the attached file for your reference.
Message 11 of 11
gustavosanmartin
