I'm using create parts on a wall to create a cladding pattern, I untick the material instances so that I can change the material to suit the desired cladding pattern. The big issue I'm finding is that patterns keep changing when the wall is being interacted with (i.e. connecting or removing connected wall or place/moving families hosted to that wall), why isn't it maintaining the pattern I changed it to? does anyone else have this issue? if so how did you get around it?
I use this method because it gives me the best of both worlds, it gives me the profile I want and also allows me to place wall base families.
@barthbradley Thank you for responding, but I'm not trying to change the original material. The issue is that the parts material keeps changing when the wall is being interacted with.
can you post pictures or a screencast that describes what you are talking about?
